Hoje é 24 Out 2026, 09:29
MensagemEnviado: 18 Mar 2010, 20:32
Data de registro: 16 Mar 2010, 12:19
Preciso saber quantas partes possui a norma 61850 e quantas são elas.
MensagemEnviado: 18 Mar 2010, 20:37
Olá.
A norma IEC 61850 em sua primeira versão era constituida de 14 partes.
Elas continuam válidas, e outras partes estão sendo debatidas para a publicação da segunda edição.
Ao fim da segunda edição, que deverá estar integralmente completa apenas em 2011 / 2012, as partes serão as seguintes:
1 Introduction and overview
2 Glossary
3 General requirements
4 System and project management
5 Communication requirements for functions and device models
6 Configuration description language for communication in electrical substations related to IEDs
7-1 Basic communication structure – Principles and models
7-2 Basic communication structure – Abstract communication service interface (ACSI)
7-3 Basic communication structure – Common data classes
7-4 Basic communication structure – Compatible logical node classes and data classes
7-410 Hydroelectric power plants - Communication for monitoring and control
7-420 Communications systems for distributed energy resources (DER) - Logical nodes
7-430 Communication system for distribution feeder and network equipment
7-5 Basic communication structure – Usage of information models for substation automation applications
7-500 Use of logical nodes to model functions of a substation automation system
7-510 Use of logical nodes to model functions of a hydro power plant
7-520 Use of logical nodes to model functions of distributed energy resources
7-10 Web-based and structured access to the IEC 61850 information models
8-1 Specific communication service mapping (SCSM) – Mappings to MMS (ISO/IEC 9506-1 and ISO/IEC 9506-2) and to ISO/IEC 8802-3
9-1 Specific communication service mapping (SCSM) – Sampled values over serial unidirectional multidrop point to point link
9-2 Specific communication service mapping (SCSM) – Sampled values over ISO/IEC 8802-3
10 Conformance testing
80-1 Guideline to exchanging information from a CDC-based data model using IEC 60870-5-101 or IEC60870-5-104
90-1 Using IEC 61850 for the communication between substations
90-2 Using IEC 61850 for the communication between substations and control centers
90-3 Using IEC 61850 for Condition Monitoring Draft
90-4 Network Engineering Guidelines
90-5 Using IEC 61850 to transmit synchrophasor information according to IEEE C37.118
MensagemEnviado: 15 Ago 2019, 12:17
Atualizando a lista anterior adiciona-se os seguintes itens:
90-7 Object models for power converters in distributed energy resources (DER) systems
90-8 Object model for E-mobility
90-12 Wide area network engineering guidelines
